Ch4rlus
Apr 20, 2021Aspirant
RAX40 Wifi SSID disapear when connecting extender
Hello, I think this topic has laready discussed in another thread here: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX40-SSID-disappear/td-p/1963851. However, I can't add a c...
- Apr 28, 2021Ok so upgrading to firmware 1.0.3.88 fixed the issue.
Now I have a dump Wifi 5 router and a working extender. I'm frustrated but at least I have something working.
Next time I'll consider other manufacturers.
Thanks a lot for the support and suggestions.
Ch4rlus
I did not use WPS to setup the extender.
I tried setting up the extender with both the android nighthawk app and the mywifiext local website, reseting the extender by pressing the reset button for 7 second in between the two tentatives.
Should I try WPS instead ?
Apr 20, 2021Guru - Experienced User
worth a shot
