Ch4rlus
Apr 20, 2021Aspirant
RAX40 Wifi SSID disapear when connecting extender
Hello, I think this topic has laready discussed in another thread here: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX40-SSID-disappear/td-p/1963851. However, I can't add a c...
- Apr 28, 2021Ok so upgrading to firmware 1.0.3.88 fixed the issue.
Now I have a dump Wifi 5 router and a working extender. I'm frustrated but at least I have something working.
Next time I'll consider other manufacturers.
Thanks a lot for the support and suggestions.
Ch4rlus
Apr 21, 2021Aspirant
I've tried resetting all devices to factory settings.
I've setted up the router first, then the extender.
Exact same issue: The wifi from RAX40 router disapears as soon as I connect the extender.
I've found that the RAX40 with firmware version V1.0.3.80 has a lot of wifi issues: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Nighthawk-Rax40-router-stops-sending-the-beacon-SSID-after-TP/m-p/1924575#M9097
Someone mentioned downgrading to the firmware version V1.0.3.64.
Do you know how I can do that ?
Apr 21, 2021Guru - Experienced User
You download the old firmware then just follow the manual firmware update process from the manual. Fairly easy to do and worth trying.
- Ch4rlusApr 28, 2021AspirantOk so upgrading to firmware 1.0.3.88 fixed the issue.
