dcalles
May 23, 2020Follower
Rax40
Hello i just buy this router rax40 model but when I try to login us a admin doesn't it say that is wrong password and this is the first time I try to login please help me
michaelkenward
May 24, 2020Guru - Experienced User
dcalles wrote:
Hello
Login how? What are you doing and where does it go wrong?
Remember, if you are using wifi, then you need to connect to that before you can login to the browser graphical user interface (GUI).
It might help if you gave us a bit more detail.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
