Halfranga
Jan 15, 2021Aspirant
Rax40
So I updated to version. 88 Can someone help me find the file 1.0.3.80 My Internet doesn't work on the new update does anyone know where to find this file due to being removed from the site plea...
Jan 15, 2021Guru - Experienced User
I couldn't find it on the support site either, it might have been pulled.
Have you tried a factory reset and clean reinstall (not from backup). thats one of the first things we recommend if there's issues after updating.
- HalfrangaJan 15, 2021AspirantI've already found it on the site, but I can't get Internet connection whatsoever on it. I have no clue how to get it back and running was fine before I updated I have no clue what settings I need. Abs netgear support is horrible it costs even though I've already paid them alot. Anyone here know how to setup a Internet connection properly (I'm slingshot)
- plemansJan 15, 2021Guru - Experienced User
so you were able to download the firmware?
You don't have to be online to do a manual update. just follow the manual update process and use the older firmware.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- HalfrangaJan 15, 2021AspirantYeah I've done so but can't get a Internet connection since factory reset. Netgear seems so difficult and netgear company as well. Can't even figure it out
