Blogan21
May 07, 2021Initiate
Rax40
So I got a new router a few days ago the ax3000 and certain apps won't load on my phone and can't figure out why. The girlfriend Is having the same issue. When I reset the router it will work for a fe...
Deillos
May 10, 2021Aspirant
i bought a used RAX40 on ebay and i am having issues getting it setup cause it is still under it's previous owners registration and support is almost non existant for transfering it to my ownership and right now it is stuck in inital setup loop i bought it for cheap as it was missing an antenna sleeve and i had to pop a button back into place. but since i am on a tight budget i was only able to buy a used one as i needed a WIFI6 AP for my Oculus Quest 2 for virtual desktop hopefully it gets resolved in 24 to 48 hours as i need to get in and configure it still.
