pointsToNull
Jul 31, 2020Aspirant
RAX40s lose WAN internet when switched to AP mode
I am trying to connect multiple RAX40s as APs for a R8000P base router with a switch in between. However, it seems I can only get one of them switched to AP mode and working. The rest work just fine ...
michaelkenward
Aug 01, 2020Guru - Experienced User
How is all this stuff wired together?
- pointsToNullAug 01, 2020Aspirant
ISP -> R8000P -> Switch -> Multiple RAX40s
ISP plugged into WAN port of R8000P
LAN port from R8000P to Switch
Switch to WAN port on the RAX40s
- michaelkenwardAug 01, 2020Guru - Experienced User
Nothing odd there, but you said "multiple RAX40s".
Thought of using one of them as the router?
Yeah I did try making one of the RAX40s the base router but I got the same results.
