pointsToNull
Jul 31, 2020Aspirant
RAX40s lose WAN internet when switched to AP mode
I am trying to connect multiple RAX40s as APs for a R8000P base router with a switch in between. However, it seems I can only get one of them switched to AP mode and working. The rest work just fine ...
pointsToNull
Aug 05, 2020Aspirant
pointsToNull wrote:..."steal" the WAN connection from the other working RAX40.
How does this appear to you resp. the systems you connect to that router supposedly in AP mode? What comes into my mind is that one RAX40 went to router mode, and started to issue local IP addresses on the LAN/WLAN (using a different subnet like 10.0.0.0/24 with the WAN on 192.168.1.0/24 (default on your R8000P).
By losing WAN I mean they have a self assigned IP and no internet connection when directly plugged into that router via ethernet.
I'd have the R8000P set up in Router mode. Connect the first RAX40 as AP mode, and all works well. Sometimes even the second RAX40 connects fine as an AP. But the next RAX40 I set up either doesn't get a WAN connection or runs fine but when I go to check on the other RAX40 APs one or more of them loses WAN and shows amber color on WAN LED.
The RAX40s definitely don't unexpectedly switch back to router mode since they never give themselves or any clients an IP. But when they truly are in router mode they work just fine.
Why would only one, sometimes two, RAX40s be able to act as AP but as soon as more are connected it because an issue? Theoretically I should be able attach as many APs as I would like as long as they fit in the IP address space.
schumaku
Aug 05, 2020Guru - Experienced User
pointsToNull wrote:Theoretically I should be able attach as many APs as I would like as long as they fit in the IP address space.
Something badly broken on either the R8000P or the RAX80 AP mode implementation, or both.
Of course - also practically - can't agree more. Afraid, can't help much as I don't have any of these devices for testing.
