lheckman77
Dec 30, 2022Aspirant
RAX41 loses connection to internet every 2 days.
My brand new RAX41 loses connection to internet every other day. It has a static IP. I have this router at my work with 11 different users most of which are connected via ethernet. Only things usi...
michaelkenward
Dec 30, 2022Guru - Experienced User
The usual questions to get the ball rolling and eliminate a few possibilities.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- lheckman77Dec 30, 2022Aspirant
What firmware version do you have on the device? V1.0.12.120_2.0.83
That was the one I installed when it came up with Firmware update available.
It is a cable modem only ARRIS Model SB6183
