LightingMcQuee7
Apr 25, 2024Aspirant
Rax41 router
I have a question I bought the router brand new and didn't know you had to pay over 300.00 dollars for some kind of lifetime plan is what the guy on the phone said and he sounded from overseas with an...
LightingMcQuee7
May 06, 2024Aspirant
Not sure about firmware cause they stopped it from updating and it's the netgear nighthawk ax5 ax3600 model#RAX41 and the ISP is starlink using the gen 2 router with the ethernet adapter cat 6 cable.I remember now he said they stopped it from updating and I needed to by the subscription for 300 a lifetime plan.
May 06, 2024Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
Ya, no, you can download FW for any NG router from here:
https://www.netgear.com/support/
And manually update it.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
They don't block updates, only if they don't want to auto update something. Thanks only on there auto update system.
