LightingMcQuee7
Apr 25, 2024Aspirant
Rax41 router
I have a question I bought the router brand new and didn't know you had to pay over 300.00 dollars for some kind of lifetime plan is what the guy on the phone said and he sounded from overseas with an...
May 06, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
LightingMcQuee7
May 06, 2024Aspirant
I had starlink router in bypass mode and had netgear plugged in the ethernet adapter
- FURRYe38May 06, 2024Guru - Experienced User
Ok.
