coltrain15
May 29, 2023Aspirant
rax41
my rax41 NTP Settings very time you change it on the new hotfix 1.0.15.128_2.0.89 it dose not let you chage it i need to change it for my games is there a way to fxi it so that i can with out downin...
michaelkenward
May 30, 2023Guru - Experienced User
Hard to follow what you are saying there.
Where are you playing with the NTP setting?
Is it normal to have to change that for games?
Have you tried a factory reset with the new firmware?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems. It is also the first thing that Netgear support will recommend.
- coltrain15May 30, 2023Aspirant
ok and i will try it out and see what happens
