Nategramm22
Oct 26, 2023Tutor
RAX42 5GHz constantly cutting out when OFDMA is on
Hello friends, I have an issue that I've put up with for over a year now. My router model is an RAX42 and I'm running firmware version 1.0.12.120_2.0.83 Here is some potentially helpful info... ...
microchip8
Oct 26, 2023Master
Have you tried firmware version V1.0.15.128?
Nategramm22
Oct 26, 2023Tutor
I haven't heard of that firmware. Are you sure it is a firmware meant for the RAX42, because when I check for firmware updates through the interface, it comes up with 'up to date'?
If you're sure I should try it, can you link a download for me?
Thanks for the response!
