Nategramm22
Oct 26, 2023Tutor
RAX42 5GHz constantly cutting out when OFDMA is on
Hello friends, I have an issue that I've put up with for over a year now. My router model is an RAX42 and I'm running firmware version 1.0.12.120_2.0.83 Here is some potentially helpful info... ...
Sparxx32
Nov 04, 2023Initiate
Having the exact same issue. after two days of troubleshooting I arrived at the same point, Turning on OFDMA on 5GHz immediately makes all devices loose connection and I can't get it back without completely resetting the router. Runs perfectly on the 2GHz band.
Router firmware is up to date as well
Hope this gets fixed soon
- FURRYe38Nov 04, 2023Guru - Experienced User
Something to contact NG support about and let them know:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
