Analog_Man
Nov 02, 2024Tutor
RAX42 Nighthawk AX5 5-Stream AX4200 WiFi Router Bridge Mode Connectivity
Using RAX42 Nighthawk AX5 5-Stream AX4200 WiFi Router in wireless bridge mode, working great to extend to four wired clients at distance from the primary router. While I can successfully connect ...
- Nov 02, 2024
I did a complete factory reset of the RAX42 this morning then reconfigured to Wireless Bridge using *only* the web interface (the app won't work for this anyway), and it seems to have resolved the problem.
Analog_Man
Nov 02, 2024Tutor
Nov 02, 2024Guru - Experienced User
