NobodyNothing99
Dec 08, 2023Aspirant
RAX43 - is WPS LED always lit?
Pretty easy one here - is the WPS light intended to always be lit regardless of whether WPS mode is active? I'd think light on = active, and light off = inactive but there is no way to manually turn ...
- Dec 09, 2023No. Only on pressing does WPS get activated and the LED starts to blink. If it does not flicker but is solid lit, it's in stand-by mode.
As I said, you need to press it to actually activate anything.
NobodyNothing99
Dec 09, 2023Aspirant
I really appreciate your response. Just to clarify, WPS LED that is lit does NOT mean that the router is in WPS mode and that clients will still need to authenticate?
I think this is what you’re stating, just want to be sure. My next step was a factory reset, lol.
Thanks!
Thanks!
microchip8
Dec 09, 2023Master
