mjaffry
Aug 15, 2024Follower
RAX43- Nighthawk AX5/AX4200- Difficulty Accessing Internet After Firmware Update w/o VPN
I updated the firmware on my Nighthawk RAX43 router this past April/May and ever since, I have had significant issues accessing the interest. I have Verizon FIOS, and prior to the firmware update, ha...
Aug 16, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does this happen to all devices?
Wireless and ethernet connections?
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What version of Fw was working for you before?
