jromine
Jan 12, 2024Aspirant
RAX43-100NAS need additional SSID
Can I ad a wifi access point to a netgear rax43-100nas to get an additional ssid?
Kitsap
Jan 12, 2024Master
jromine wrote:Can I ad a wifi access point to a netgear rax43-100nas to get an additional ssid?
The basic answer to your question is yes. Would have to ask if you have your RAX43 configured to give you separate SSID's for the normal Wi-Fi 2.4 GHz and 5 GHz bands plus the guest Wi-Fi options? Usually that results in a total of four different SSID's.
With your present configuration, do you have only one SSID with all of the bands merged together?
- microchip8Jan 12, 2024Master
That's kind of a weird question. You want an additional SSID for some reason or do you want to extend your coverage?
- jromineJan 12, 2024Aspirant
Needs have changed. now need additional SSID that can be used for wireless printer that others do not have access to.
Currently 2 SSID's will reconfigure 5ghz and try that thanks!
