jromine
Jan 12, 2024Aspirant
RAX43-100NAS need additional SSID
Can I ad a wifi access point to a netgear rax43-100nas to get an additional ssid?
Kitsap
Jan 12, 2024Master
jromine wrote:Can I ad a wifi access point to a netgear rax43-100nas to get an additional ssid?
The basic answer to your question is yes. Would have to ask if you have your RAX43 configured to give you separate SSID's for the normal Wi-Fi 2.4 GHz and 5 GHz bands plus the guest Wi-Fi options? Usually that results in a total of four different SSID's.
With your present configuration, do you have only one SSID with all of the bands merged together?
jromine
Currently 2 SSID's will reconfigure 5ghz and try that thanks!
