Mars92
Dec 28, 2021Aspirant
RAX43 5Ghz network unstable
*Router is actually RAX43 but for some reason that wasn't an option. I can't seem to get a stable connection to a 5Ghz network on my PC that lasts longer than 5 seconds. I recently switched ISPs ...
- Jan 05, 2022
Update for anyone reading this in the future: After troubleshooting and talking to Netgear support, we determined it was faulty and I returned the router and replaced it, I haven't had any issues with the new one since then. So if you're having a similar issue to me, you might need a replacement unit.
michaelkenward
Dec 29, 2021Guru - Experienced User
What are you using as a modem, if there is one, to connect to the Internet?
the Eero router they provided capped out at 500mb/s over wifi, and since most of my devices connect through wifi I decided I should upgrade to something that could deliver the speeds I'm paying for.
How many of your wifi devices are actually capable of speeds faster than 500 Mbps? Most aren't.
- Mars92Dec 29, 2021AspirantThe modem is a Huawei ONT, wired into the house as a part of the NZ Government's Fibre rollout.
As for speeds over 500mb/s, my PC, work laptop and iPad all support WIFI 6. I did manage to see the full speed of my connection on my PC during testing, but the instability of 5ghz makes that useless.- michaelkenwardDec 29, 2021Guru - Experienced User
Mars92 wrote:
The modem is a Huawei ONT, wired into the house as a part of the NZ Government's Fibre rollout.That doesn't telll us what it is. Just the brand name. The question was intended to find out if the Internet came through something that is also a router. That isn't common, but isn't unknown and complicates network management.
It's an ONT thats made by Huawei, that's all I know. I didn't pick it, it's the same ONT that basically every house in New Zealand got during the national fibre rollout.
It's an issue with the 5Ghz local network, I don't really see how the model of the ONT has any impact. I know it works fine because I can plug the Eero router back in and it works as expected.
