Mars92
Dec 28, 2021Aspirant
RAX43 5Ghz network unstable
*Router is actually RAX43 but for some reason that wasn't an option. I can't seem to get a stable connection to a 5Ghz network on my PC that lasts longer than 5 seconds. I recently switched ISPs ...
- Jan 05, 2022
Update for anyone reading this in the future: After troubleshooting and talking to Netgear support, we determined it was faulty and I returned the router and replaced it, I haven't had any issues with the new one since then. So if you're having a similar issue to me, you might need a replacement unit.
Mars92
Dec 29, 2021Aspirant
The modem is a Huawei ONT, wired into the house as a part of the NZ Government's Fibre rollout.
As for speeds over 500mb/s, my PC, work laptop and iPad all support WIFI 6. I did manage to see the full speed of my connection on my PC during testing, but the instability of 5ghz makes that useless.
michaelkenward
Dec 29, 2021Guru - Experienced User
That doesn't telll us what it is. Just the brand name. The question was intended to find out if the Internet came through something that is also a router. That isn't common, but isn't unknown and complicates network management.
- Mars92Dec 29, 2021Aspirant
It's an ONT thats made by Huawei, that's all I know. I didn't pick it, it's the same ONT that basically every house in New Zealand got during the national fibre rollout.
It's an issue with the 5Ghz local network, I don't really see how the model of the ONT has any impact. I know it works fine because I can plug the Eero router back in and it works as expected.
Sorry if that came off as rude, this has been an ordeal. I can tell you with some certainty that the ONT is not also a router, just the modem.
