Mars92
Dec 28, 2021Aspirant
RAX43 5Ghz network unstable
*Router is actually RAX43 but for some reason that wasn't an option. I can't seem to get a stable connection to a 5Ghz network on my PC that lasts longer than 5 seconds. I recently switched ISPs ...
- Jan 05, 2022
Update for anyone reading this in the future: After troubleshooting and talking to Netgear support, we determined it was faulty and I returned the router and replaced it, I haven't had any issues with the new one since then. So if you're having a similar issue to me, you might need a replacement unit.
Mars92
Jan 05, 2022Aspirant
Jan 05, 2022Guru - Experienced User
Enjoy. 📡
