mangotango
Nov 09, 2022Guide
RAX43 autoupdated firmware, changed SSIDs, and now wifi is very sporadic
Last night my RAX43 did some sort of auto-update/factory reset, which put my SSIDs back to factory defaults. I fixed that, reconnected wifi, but now the problem is the wifi signal keeps cutting out...
Nov 09, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? I recommend giving a reset and setup from scratch WITHOUT loading any saved backup configurations from file a try.
- microchip8Nov 09, 2022Master
People, DISABLE auto-update. With the current state of NG firmware it can even brick your router, not just reset it!
I did a manual update and no issues here so far.
