mangotango
Nov 09, 2022Guide
RAX43 autoupdated firmware, changed SSIDs, and now wifi is very sporadic
Last night my RAX43 did some sort of auto-update/factory reset, which put my SSIDs back to factory defaults. I fixed that, reconnected wifi, but now the problem is the wifi signal keeps cutting out...
Razor512
Nov 09, 2022Prodigy
Seems to also be impacting the RAX50 as well.
Best to do a factory reset and and set up from scratch.to rule out any potential for issues given how this update is behaving for some users.
mangotango
Nov 09, 2022Guide
My RAX43 did a factory reset last night because it auto updated to new firmware, which then screwed everything up. I had to revert to older firmware, and then disable Autoupdate so this doesn't happen again.
