Alpinebs
Mar 20, 2022Tutor
RAX43 dropping WAN from 1G/1G to 500Mb/80Mb
Im curious if there has been any resolution to the reduction of available bandwidth on netgear routers. Using an RAX43 AX4200 on a balanced gig fiber connection and as every other thread ive read, it...
microchip8
Mar 20, 2022Master
I don't have a symmetric 1Gbps/1Gbps connection, but I had no problems hitting 1 Gbps download even after 2 weeks of operations on my RAX43. My upload is only 50 Mbps so I can't test that.
Which firmware version are you using? (not "the latest", a number)
What modem are you using?
- AlpinebsMar 20, 2022Tutor
microchip8 , the latest firmware
JK, V1.0.10.110_2.0.75
its a fiber connection so no modem. Gigpoint 803G media converter.
- microchip8Mar 20, 2022Master
I have the same FW as you and no issues here. Do you have traffic meter enabled?
Also, what modem/ONT is in front of the RAX43?
You can try factory reset and reconfigure from scratch (don't use a saved settings file. It defeats the purpose of factory reset)
microchip8 , ONT edited into previous reply.
no traffic meter
have attempted factory default with scratch config, one HW PC then iMAC (both 1000Mbps ethernet connection established to router) connected at a time. same result. shows 925/950 for a period of time after reboot then drops into 250/80 through HW connection and 450-600/80 through wireless connection.
- Guru1911Mar 28, 2022AspirantCheck your mtu settings
