Alpinebs
Mar 20, 2022Tutor
RAX43 dropping WAN from 1G/1G to 500Mb/80Mb
Im curious if there has been any resolution to the reduction of available bandwidth on netgear routers. Using an RAX43 AX4200 on a balanced gig fiber connection and as every other thread ive read, it...
Alpinebs
Mar 20, 2022Tutor
microchip8 , the latest firmware
JK, V1.0.10.110_2.0.75
its a fiber connection so no modem. Gigpoint 803G media converter.
microchip8
Mar 20, 2022Master
I have the same FW as you and no issues here. Do you have traffic meter enabled?
Also, what modem/ONT is in front of the RAX43?
You can try factory reset and reconfigure from scratch (don't use a saved settings file. It defeats the purpose of factory reset)
- AlpinebsMar 20, 2022Tutor
microchip8 , ONT edited into previous reply.
no traffic meter
have attempted factory default with scratch config, one HW PC then iMAC (both 1000Mbps ethernet connection established to router) connected at a time. same result. shows 925/950 for a period of time after reboot then drops into 250/80 through HW connection and 450-600/80 through wireless connection.
- microchip8Mar 23, 2022Master
I have no idea why your speeds drop after a while. I suspect (but could be wrong) that CTF (HW acceleration) is being disabled due to something. Maybe plemans can chime in
- plemansMar 23, 2022Guru - Experienced User
Try reinstalling the firmware on it. Maybe something is corrupt in the firmware causing issues. A factory reset only clears out settings.
You could also try downgrading the firmware a version in case its an issue with the current version of the firmware.
