Alpinebs
Mar 20, 2022Tutor
RAX43 dropping WAN from 1G/1G to 500Mb/80Mb
Im curious if there has been any resolution to the reduction of available bandwidth on netgear routers. Using an RAX43 AX4200 on a balanced gig fiber connection and as every other thread ive read, it...
microchip8
Mar 20, 2022Master
I have the same FW as you and no issues here. Do you have traffic meter enabled?
Also, what modem/ONT is in front of the RAX43?
You can try factory reset and reconfigure from scratch (don't use a saved settings file. It defeats the purpose of factory reset)
Alpinebs
Mar 20, 2022Tutor
microchip8 , ONT edited into previous reply.
no traffic meter
have attempted factory default with scratch config, one HW PC then iMAC (both 1000Mbps ethernet connection established to router) connected at a time. same result. shows 925/950 for a period of time after reboot then drops into 250/80 through HW connection and 450-600/80 through wireless connection.
- microchip8Mar 23, 2022Master
I have no idea why your speeds drop after a while. I suspect (but could be wrong) that CTF (HW acceleration) is being disabled due to something. Maybe plemans can chime in
- plemansMar 23, 2022Guru - Experienced User
Try reinstalling the firmware on it. Maybe something is corrupt in the firmware causing issues. A factory reset only clears out settings.
You could also try downgrading the firmware a version in case its an issue with the current version of the firmware.
- AlpinebsMar 23, 2022Tutor
plemans I certainly might try to reinstall firmware. So far its all been amending the existing installed firmware. I'm assuming that will also erase my configuration, yes?
I think I'm falling victim to two problems being the ISP service consistency which they are thankfully fully involved in fixing and something I don't understand happening in the router.
I'm going to focus my attention on the speed to the house first then dive into the router again if I still see anomalies.
microchip8 is the HW accel something that can be seen or controlled? I've seen it mentioned but dont know how to manage it.
Additional update, BerryComm is working on an issue in the area. We are getting slower than expected and erratic speeds at the fiber converter. Seeing 450/650 consistently, less at times, but none of the readings at the interface seem to match the random but consistent 240/80 that the router will produce from time to time. Its almost like the router is going into a degraded or safe mode which is why I'm curious about your HW acceleration comment. Is it possible the router's assessment is dynamic and responds to packet loss and degrades the available reading based on what it is able to reliably push?
Alpinebs wrote:microchip8 is the HW accel something that can be seen or controlled? I've seen it mentioned but dont know how to manage it.
CTF on Broadcom is a black box. No one really knows how it operates (not even the ASUS folks). There's no cheat sheet on how it works and wen it gets enable//disabled. As I said, it's a black blob box. Only Broadcom know how it works.
