Alpinebs
Mar 20, 2022Tutor
RAX43 dropping WAN from 1G/1G to 500Mb/80Mb
Im curious if there has been any resolution to the reduction of available bandwidth on netgear routers. Using an RAX43 AX4200 on a balanced gig fiber connection and as every other thread ive read, it...
Mar 23, 2022Guru - Experienced User
Try reinstalling the firmware on it. Maybe something is corrupt in the firmware causing issues. A factory reset only clears out settings.
You could also try downgrading the firmware a version in case its an issue with the current version of the firmware.
Alpinebs
Mar 23, 2022Tutor
plemans I certainly might try to reinstall firmware. So far its all been amending the existing installed firmware. I'm assuming that will also erase my configuration, yes?
I think I'm falling victim to two problems being the ISP service consistency which they are thankfully fully involved in fixing and something I don't understand happening in the router.
I'm going to focus my attention on the speed to the house first then dive into the router again if I still see anomalies.
