davidaz
Apr 08, 2024Aspirant
RAX43 fast roaming
Can I turn off “fast roaming”? Having issues with Circleview camera and they suggest turning off fast roaming to see if it make any difference. Can not find where in settings that I can turn it of...
michaelkenward
Apr 08, 2024Guru - Experienced User
And those issues are? Is "they" the people who make the Circleview?
That's not something you'll find mentioned in most Netgear manuals. Perhaps it goes under another name.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
davidaz
Thx for the reply. Issues are that the camera was working fine for many months. Dropped out once in a while…maybe 2-3 times. it now will not stay connected. I have done a complete reset of the camera and a delete/reinstall of the Circleview camera in HomeKit and it drops out (says “no response”) after less than a day? Apple suggested installing from another device, which I have done and still not staying connected to WiFi.
The “they” I referenced in my post, was Logitech (the manufacturer of the camera). I read in one of their forums to try turning off fast roaming, then test to see if it works.
can’t find a where to turn off in RAX 43 settings?
