Dshow
Feb 25, 2024Aspirant
RAX43 internet drops out. Thoughts on why?
Hi, I have a Netgear Nighthawk AX5 ax4200 5- Router that I use from streaming over WIFI. About every day or so, the WIFI stops. The last time it did that, I connected my computer via an ethernet c...
Dshow
Not sure what you mean by "did you enable and configure it?"
I set up a 2.4, 5G, and Guest networks and I also have a thumb drive in the USB port.
What do I need to enable and configure?
I'm presently evaluating the Verizon 5G which has a router... (I had it set to pass through mode to work with my router.)
Retired_Member
Feb 25, 2024I'm not familiar with the Nighthawk App on a smartphone.
but I've read some recent threads here explaining that's the one-and-only place to configure Armor.
what I was getting at was, (oppositely)
maybe by disabling Armor, one variable in this equation could be excluded
to narrow down the source of the problem.
