larrydrum
Apr 01, 2021Aspirant
RAX43 internet light is red
I've check the manual and there is nothing that say what a red "internet" light means. I have internet access and everthing is working. Performance is good at about 570 mbps. Desktop Computer and V...
larrydrum
Apr 02, 2021Aspirant
I think I found solved it. On this router the red light indicates that you have a LAN connecition. On my older model R7000 it did not turn read unless I did not have internet connection.
- Christian_RApr 08, 2021NETGEAR Employee Retired
Hello larrydrum,
Thanks for providing an update to your post as it may possibly help others in the future.
Christian
