pizzaman029
Nov 09, 2022Aspirant
RAX43 just factory reset overnight on its own
Does anyone know how / why this happens? I saw another post from a few months back were something similar occurred "COINCIDENCE" is that yesterday was the same exact date my technical support ex...
Nov 09, 2022Guru - Experienced User
Maybe the firmware updated or a power surge triggered it.
Should just be able to run back through setup and be fine.
a backup might be nice for next time (if there is one)
- pizzaman029Nov 09, 2022Aspirant
Yes - I fixed it but that's not the point! I want to know why it happened.
A power surge should in no way cause a factory reset! I don't think I believe that.
And a firmware update shouldn't crap out all your settings without warning. That is a bad design
