Ah_Wah
Nov 26, 2022Tutor
RAX43 must disable OFDMA to work with Killer AX1675i adapter
Nighthawk RAX43, Operation Mode: Access Point, Firmware Version: V1.0.12.120_2.0.83 New laptop running Win11 and using Killer WiFi 6E AX1675i 160MHz (211NGW) adapter. Every time AX1675i conne...
Nov 27, 2022Guru - Experienced User
Did you try factory resetting the router and testing it in its default configuration?
- microchip8Nov 27, 2022MasterOFDMA is not compatible with all devices. Even if it is, you'll see minor gains.
