Ah_Wah
Nov 26, 2022Tutor
RAX43 must disable OFDMA to work with Killer AX1675i adapter
Nighthawk RAX43, Operation Mode: Access Point, Firmware Version: V1.0.12.120_2.0.83 New laptop running Win11 and using Killer WiFi 6E AX1675i 160MHz (211NGW) adapter. Every time AX1675i conne...
Nov 27, 2022Guru - Experienced User
Did you try factory resetting the router and testing it in its default configuration?
microchip8
Nov 27, 2022Master
OFDMA is not compatible with all devices. Even if it is, you'll see minor gains.
