Aljesh
Feb 22, 2021Aspirant
rax43 No connection to telstra modem after firmware update
Nighthawk AX5 AX4200 5-Streem Wifi Router Recent update of Firmware Caused the router to not pick up internet connection from modem. internet light is red. New network cable.
Feb 22, 2021Guru - Experienced User
What modem/gateway is it?
What firmware version did you install?
did you try a factory reset and reinstall? Anytime there's issues after a firmware change, its a reasonable option.
