Aljesh
Feb 22, 2021Aspirant
rax43 No connection to telstra modem after firmware update
Nighthawk AX5 AX4200 5-Streem Wifi Router Recent update of Firmware Caused the router to not pick up internet connection from modem. internet light is red. New network cable.
Aljesh
Jul 21, 2021Aspirant
Same Issue With A Ñew Version Of The Firmware.
Modem Is A Smart Modem Gen2 Lh100 Red Box (arc)
This is A New Unit.
No Internet Connection Still.
Jul 21, 2021Guru - Experienced User
That modem has its own integrated router functions. It does cause a double nat.
options (only use 1)?
1. put the LH1000 in modem only/passthrough mode.
2. put the netgears IP address into the LH1000's DMZ
3. put the netgear in access point mode.
