DenimDick
Aug 01, 2022Initiate
RAX43 (sudden) drop in Wifi Speed
Product: Netgear NightHawk RAX43 Approx. 1 Yr. Old (just out of warranty) Problem: 1.Until yesterday: a. Ethernet Speed of 300 - 325 Mbps b. Wifi: 2.4 Ghz speed btw 250 and 300 Mbps - fr...
DenimDick
Aug 02, 2022Initiate
Thank you for the reply / suggestions Plemans!
RE:
1. " reinstalling ... " I will update the post on this one. I have held out on reinstalling (flashing) the firmware as I have the ISP service tech coming out to take a look at their equipment. If they don't find anything wrong on their end I will try this 🙂
2. "... never seen .." I think I overstated the 2.4Ghz speed - although I was looking at through put and not link speed. I went back and viewed my history of tests and the highest that I hit on 2.4 was 240. I was testing right next to the router so distance did not come in to play for this (stored) result.
3. ".... hitting 300 .. " Yep. But I am in an area north of PHX were all the homes are on 1 to 1 1/3 acres with no two-story homes and no powerlines. We are also nestled between 3 (not yet sold) "state trust land" plots (1 sq mile each) so not a lot of interference from commercial development.
Again, thank you for the response and I will update the post once I have greater insight from my ISP tech.
Best Regards,
Rick
Aug 02, 2022Guru - Experienced User
Glad to see you hitting those speeds on the RAX43.
The review of the RAX40 is more along the max lines of 150mbps.
https://dongknows.com/netgear-rax40-ax4-wi-fi-6-router-review/
The RAX50 gets a more 180mbps but thats a little higher performing router.
https://dongknows.com/netgear-rax50-nighthawk-ax6-wi-fi-6-router-review/
If you're hitting it, great to hear. Kudo's to you.
