ristau77
Oct 13, 2022Aspirant
RAX43
Nighthawk RAX 43 purchased 6/1/2022
Cannot access internet, message trying to access Gmail or any other site:
Your connection is not private
Attackers might be trying to steal your information from mail.google.com (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_AUTHORITY_INVALID
I have powered off and back on, reset to factory settings and still cannot get by the error message above. HELP
NET::ERR_CERT_AUTHORITY_INVALIDYou have not provided much detail about what you are doing and what you have tried to do to fix it. That makes it hard to tell where you should look to fix your problem. So we have to fall back on generic suggestions.
Messages like this can be down to various things. The router isn't usually one of them. People just blame that because it is there.
From time to time browsers "improve" their approach to security and add new layers of protection. Which one are you using?
Have you tried a different browser?
Another possibility is that your operating system has changed and is trying to protect you from wicked people on the Internet.
One possibility is that you could tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
I'm told that this is rubbish advice. But it has worked for me and others in the same boat.
- ristau77Aspirant
taking google off default seems to have corrected the problem.
I'm not sure what that means, but if it works for you, that's good.
Sounds like it has nothing to do with your router.
