nertho
Mar 04, 2024Aspirant
RAX43v2 can't log in to web interface
Model: RAX43v2 Firmware: RAX43v2-V1.1.4.28_2.1.26 Reset performed: YES What is actually going on here? Have the login servers on Netgear's side been infected with some ransomware or somet...
Retired_Member
Mar 04, 2024
https://accounts-qa.netgear.com/error?redirectUrl=http:%2F%2F192.168.1.130%2Fgenie_redirect_SSO.htm&serial_num=5G018A7EA006B
https://accounts-qa.netgear.com/error?redirectUrl=http://192.168.1.130/genie_redirect_SSO.htm&serial_num=5G018A7EA006B
fascinating isn't it?
maybe somebody here will help you brainstorm a workaround that's friendlier than a firmware meltdown.
