akt111
Jun 10, 2020Tutor
RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router - Parental Controls
Hi, I purchased the RAX-45 router with an understanding that it will support some good parental controls, through the Nighthawk app as advertised under the below link. The link does not outline it v...
Jun 10, 2020Guru - Experienced User
The RAX devices have been getting services added to them the older they get.
When they were released, the AX spec wasn't even finalized. So they focused on getting the devices up and running properly and then added services/features.
For instance, the RAX200 (flagship router), just got the rollout of netgear armor and circle/parental controls on June 8th.
I'd imagine these features are going to trickle down the chain but netgear doesn't release dates because to many things influence when they're released. Such as bugs, social issues (covid), and even firmware from the hardware makers (broadcom, qualcomm, etc)
bc808
Aug 02, 2020Initiate
August 1st.... anything for parental control?? If not, I'm returning it. I got this router to remedy control over my kids over using the internet. Parental controls should be standard, like before. Please advise how to get this function for such a pricey router.
- akt111Aug 12, 2020Tutor
Received a firmware upgarde today and was very hopeful but unfortunately even with the new firmware upgrade there is no support for parental controls in nighthawk app or circle.
Quite disappointed with the router because of not having the parental control feature. I am also noticing that range also is not so great. It's advertised for more than what it offers.
- wliu2Aug 17, 2020Guide
Same here. This is critical to me as I have kids surfing internet. Router level parental control is essential in this situation. Don't understand why it is so difficult to implement it, espcially for openDNS live parental control.
- sambaredNov 18, 2020Initiate
I am facing same issue. Please help me to get parental controls for Nighthawk RA~X45 ASAP. i can't even return my return is crossed:smileysad:
- CharlesW96Dec 15, 2020Initiate
No Parental control, I will return it too.
