dlflemingos
Jun 28, 2021Aspirant
RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router keeps going offline
The router is 6 months old and recently starting going offline 4-5 times/day. Phone wifi says connected no internet and wired has no internet and neither can access the router. Sometimes I see authentication error on my phone. I seem to have the latest firmware. Reseting the cable modem doesn't help. Rebooting the router fixes it for a few hours. This morning, I reset the router and it's still dropping offline.
This is a huge problem as it drops in the middle of meetings, etc. Need to fix or get a new router quickly and not sure I want another RAX45 until I figure out what's going on.
Not sure why RAX45/AX6 isn't in the model pulldown menu.
what modem do you have?
Are you sure its the router? if its happening 4x a day, direct wire a pc/laptop into the modem and use it. If its still dropping, then you'd need to look at the modem or the line from the ISP. If it doesn't drop, then we can further investigate the router. I recommend doing this because it stinks burning hours trying to fix something and you come to find out that device wasn't the issue
- dlflemingosAspirant
The modem is Charter Specturm Hitron E31N2V1 and it's about 3 months old. The old one was dropping off daily. Turns out we had a very old modem and a weak signal. The modem dropping had different symptoms (could still connect to the wifi and router - just no internet) and was fixed by rebooting the modem. Now rebooting the modem does not help.
The symptoms this time are you can't connect to the router wired, wifi or with the nighthawk app (wifi). Fortunately, rebooting the router works for about 2-3 hours.
I have hooked up directly to the modem and that works fine.
I meant to post
Firmware Version V1.0.2.82_2.0.50 - plemansGuru - Experienced User
Have you tried downgrading the firmware a version? Some of these newer firmwares gets updates for the underlying coding (from broadcomm/intel/qualcom/etc) and they can introduce bugs.
