wsamh
Mar 12, 2021Follower
RAX45 - had to factory reset twice
I have a RAX45 router. the last couple of weeks I've had to factory reset. the first time, for some reason all my device could not connect. nor the connecting directly with ethernet. Just today the w...
Christian_R
Mar 16, 2021NETGEAR Employee Retired
Hello wsamh,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
