j-d-m
Jun 17, 2020Tutor
RAX45 - WPA3 -> WPA2 fallback?
Is there a way to enable this router to fallback to WPA2-PSK for devices that can't connect using WPA3? It didn't seem to happen automatically as I had a few devices that couldn't connect and I didn'...
schumaku
Jun 17, 2020Guru - Experienced User
There is a handshake finding the best method ... if this goes out to WPA3(-AES anyway) it won't return to a lower level. Same if WPA2-AES is negotiated and something goes wrong ...
