paneubert
Dec 16, 2020Aspirant
RAX45 / AX4300 speed test run from INSIDE router shows 50% expected speed.
Hello; RAX45 / AX4300 speed test run from INSIDE router shows 50% expected speed. Just got gig speed upgrade today (from 50/50 before). Immediately after fiber setup/upgrade on outside of my...
Dec 17, 2020Guru - Experienced User
its not a firmware issue, its an issue of the integrated speedtest in the app.
Problem with it is that it chooses the closest server, not the fastest server. so we see frequently that people don't think they're getting the full speeds because the built in speedtest through netgear doesn't show it. Tends to happen a lot with people on gigabit because its a challenge to fully saturate.
The best way is the hardwired test using the actual speedtest in the browser but even that sometimes chooses a poor server. so we usually recommend trying the speedtest site, dslreports, and even google/xfinity's speedtests just to give you a rough idea.
paneubert
Dec 17, 2020Aspirant
Thanks. I did notice as I was searching for "gig capable" speed test sites that even the Google Fiber one has a disclaimer that it starts to become inaccurate for speed tests at about ~700. Which I think is funny since it is a Google Fiber specific speed test and most people on Google fiber probably are paying for gig speeds.
