siberian
Dec 07, 2020Aspirant
RAX45 5G network not available
Dual 2G and 5G router. 5G is no longer seen. Any idea why this happens?
siberian
1 Reply
- siberianAspirant
PBCAK alas. Set it to "smart" connect meaning that both needs both networks to have the same SSID thus it takes the 2.4Ghz net and whatever name you give it it will assign to the 5Ghz one and grey it out. A single SSID then shows for either. I disabled it. Sorry for the entry
siberian
