myprofile
Oct 25, 2023Aspirant
RAX45 Access Control Not Persistent - Allowed Devices get Blocked upon Router Restart
Greetings, At the moment, the access control feature of my RAX45 is enabled, and set to "Block all new devices from connecting". Whenever the router reboots, some of the "allowed" devices are droppe...
- Oct 28, 2023
My RAX45 was not behaving right. For example, the allowed list and blocked list were identical. When a MAC address was deleted from blocked list, it would also delete from allowed list. So, I ended up resetting the router, and reconfiguring it again. So far, it is working fine, and there are just about 25 devices allowed. I have not configured the address reservation just yet.
Thank you for your responses and assistance.
myprofile
Oct 26, 2023Aspirant
Without counting, I am very sure that my allowed list has more than 25 devices. This limit is quite annoying. I suspected such limitation but didn’t bother to check the data sheet.
I wonder what is the limit for AX5400. I had similar device count with the older R7000 and do not recall having such limitation.
myprofile
For each of the various routers, the data sheet states the following:
- RAX4300: "handle up to 25 device"
- RAX5400: "suitable for up to 25 connected devices"
- R7000: "you get multi-layered cybersecurity for an unlimited number of devices'
Not sure if one should not read too much into the difference in verbiage, or read between the lines. But in anyway simultaneously connected device limit I can understand, and if true, there is hardly a time when I have 25 connected devices simultaneously.
I will have to figure a workaround for now, but this is really a shortcoming on Netgear's part. Router allows to configure more than 25 static IP's (there are 37 configured right now). So this limit of 25 devices does not apply to static IP, but does to access control list.
Besides, I am very much sure that more than 25 devices can connect to the router simultaneously, it's just that performance will start to degrade. Tempted to test.....!
- KitsapOct 26, 2023Master
The parameters are not clearly defined. Some background on Wi-Fi connections.
https://kb.netgear.com/24043/How-many-WiFi-client-devices-can-my-NETGEAR-router-support
- myprofileOct 28, 2023Aspirant
- michaelkenwardOct 26, 2023Guru - Experienced User
Static and reserved IP addresses – which can mean different things depending on where you set them, router, device or ISP – are not the same thing as wifi connections.
