javidelgadillo
Apr 28, 2021Tutor
RAX45 and Ooma
Hello, I recently upgraded from Nighthawk X6S model R7960P to Netgar AX6 RAX45. I had the Ooma Telo Air Wireless (https://www.ooma.com/telo/wireless-voip-phone-adapter/) connected with via Wifi...
javidelgadillo
Apr 29, 2021Tutor
Tried both at the same time. It got better but still experienced intermittent choppiness when listening. Instead of attaching via WiFi, moved the Ooma base and connected it via ethernet cable to the router. That's better. Just sucks since there isn't much space for the phone base where router is located.
Apr 30, 2021Guru - Experienced User
Have you tried changing what wireless channel is used for 2.4ghz?
What actual hub do you have for ooma?
- javidelgadilloMay 03, 2021Tutor
haven't tried changing the channel. Ive got the Ooma Telo Model No: TELOAIR105.
How will changing the channel affect all of the other devices that are currently connected on the 2.4GHz wireless?
-Javier
- plemansMay 04, 2021Guru - Experienced User
2.4ghz is sensitive to interference. Changing the wireless channels used could make other devices function better if you're moving to a less congested 2.4ghz channel.
