wrd
Jun 15, 2020Tutor
rax45 AX6 No I phonen need to get installation directions on my home computer
Bought a AX6 yesterday. I do not have an I phone and cannot find installation instructions to download to my computer. Need detailed help with that. I have a cable modem from TDS and that works we...
- Jun 15, 2020
AX6 == RAX45/RAX50 model in this case (it's a duplicated post by the way, have replied before).
Assuming you managed to connect your computer to the wireless (using the default SSID/Network Name and unique Security Key/Wireless Password printed on the product label) or can connect a network cable from your computer to one of the device LAN ports, start here:
Nighthawk AX6 6-Stream AX4300 WiFi Router Model RAX50 User Manual from around p.17 (more reading is always good for learning and understanding of the product) with the chapter 2. "Connect to the Network and Access the Router".
Works exact the same easy way as shown in the QSG, don't worry!
wrd
Jun 15, 2020Tutor
Well, I think it worked? My computer indicates that I have internet and the wi-fi is hooked up. Now I need to see if my tv streaming like netflix works. Honestly I have no clue how this happened. Thank you for your help.
