krk_
Oct 05, 2023Aspirant
RAX45 Bricked After Firmware Update
Router had a firmware update and was tracking progress on the app. Upgrade process never finished and router was rebooted. It is now not functional. The power LED is just on solid, but none of the...
Oct 05, 2023Guru - Experienced User
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflash
krk_ wrote:
Router had a firmware update and was tracking progress on the app. Upgrade process never finished and router was rebooted. It is now not functional. The power LED is just on solid, but none of the Ethernet ports have link lights, WiFi indicators off, etc. I tried to connect directly to my PC via Ethernet cable and do not get any response. Any way to recover? Reading through multiple posts, normally power LED flashing or amber if firmware was corrupted. Afraid it is just toast.
