krk_
Oct 05, 2023Aspirant
RAX45 Bricked After Firmware Update
Router had a firmware update and was tracking progress on the app. Upgrade process never finished and router was rebooted. It is now not functional. The power LED is just on solid, but none of the...
krk_
Thank you. Tried most of these but the 30:30:30 item. TFTP is not an option currently because I can’t even get link on any of the Ethernet ports.
michaelkenward
Oct 05, 2023Guru - Experienced User
No link detected or the LEDs don't work?
- krk_Oct 05, 2023AspirantNeither. No link lights on the router and NIC not showing connected on computer.
- FURRYe38Oct 05, 2023Guru - Experienced User
What happens with the 30-30-30 reset?
TFTP would reveal same thing as 30-30-30 reset if ports are bad or not.
- krk_Oct 06, 2023AspirantWell, nothing worked. No response from the 30;30;30 reset, no communications on any of the Ethernet ports, etc. I think it either had a hardware failure or is just beyond repair. Thanks to everyone for the suggestions.
