heybart
Dec 16, 2021Aspirant
RAX45 cannot enable FTP over internet
I have a USB 3.0 drive connected to RAX45. I have smb sharing internally working, and I can enable internal FTP. But I cannot enable FTP over internet. The check box to enable it cannot be checked. ...
Dec 17, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
microchip8
Dec 17, 2021Master
I do not recommend enabling plain FTP on the Internet connection. FTP is an inherently insecure protocol and various browsers are phasing out support for it (Chrome already has in its latest version). If you value your files/content, do not use it. It's easy to hack an FTP server
